Sluggish G70 2.0T
hejpath
Detroit, MI
I enjoy driving this car for the most part, but it seems extremely sluggish from a standing start. If it's turbo lag, it's the most extreme I've ever experienced. I know the awd adds substantial weight. Any thoughts?
EdP
Supporting Member
SUPPORTING MEMBER
7,808
4,078
Parrish, FL
8800 miles. Previous car was a Kia Optima 2.0T. Seemed faster with very little turbo lag.
Depending on model and options you may be moving an extra 300 - 500 pounds or more. Gearing may be different.
Talk to your dealer and drive another G70 AWD and see if it feels the same or different and have them drive yours. Unless we drive your car we really can't tell if it is as expected or not. Sort of like asking if your pillow is too soft.
hejpath
Detroit, MI
Thanks. I considered those performance factors. Thought others might have the same impression. Will try your suggestions.
hejpath
Detroit, MI
The AWD 2.0T G70 and the RWD do feel quite different. I think the AWD feels heavy.
It's funny but I also feel more grunt off the line in ECO than SPORT.
The AWD IS heavy, but RWD is apparently unavailable here in Michigan. I definitely have to try The ECO launch.
Cereal Box
3.3 here and I think it's the traction because it does weird things and the car responds differently every time you punch the throttle on a stopped or a rolling start
It allows slip sometimes and its super fun but other times the car doesn't respond the way I'd like it too. Feels sluggish and doesn't downshift quickly enough.
Try turning the traction off but leave stability on because it doesn't really kick in unless you do something really stupid.
Husky
805
93
I wonder if this lag is (at least in part) due to the drive by wire throttle. It's pretty bad in many BMWs. Although I don't notice any in my 3.3T, especially in Sport mode, many 2.0 owners have complained about this.
PJ Genesis
31
New G70 2.0T AWD owner here. I feel a bit of lag, but it goes away nearly instantly if you just push the throttle a bit more. Felt worse lag in a high powered Mercedes with a naturally aspirated V8. The 2.0T is pleasantly fast, I was a bit afraid it would feel sluggish. Maybe a reflash would improve it, but it just feels like it is part of the car's character.
rmod
80
Just curious. Were you able to get this issue solved?
PJ Genesis
31
Another thought here...a G70 2.0T AWD with a passenger or two weighs close to 2 tons. Moving this thing is a 120 cu. in. 4 cyl engine. Lets not forget the turbo from a standstill is nothing but dead weight until it spins up. The AWD system adds friction, mass and rotational inertia to overcome from a standstill. Not sure who makes the turbo, but it probably is not as strong from low rpm as the BMW units. If anyone has ever driven a new Porsche Cayman or Boxster, they are also laggy from a standing start. While I am not saying nothing can be done about this, there are trade offs from asking a small 4 cylinder engine to produce near V8 power. The lag isn't that bad in my car, I appreciate the fuel savings in bumper to bumper traffic and power when called upon.
Toddasaurus
REEEEEEEEEEEEEEEE!!!!!
3,275
4,365
The turbo is by Garrett/Honeywell. It's a twin scroll, it should spool pretty dang quick. I think some of the "lag" experienced is from the ECU tuning.
After installing my EWG control for the JB4 I noticed quicker spool on my 3.3tt, it also hit MUCH harder when boost kicked in. On top of the purposefully sluggish wastegate control, the ECU also modulates the throttle plate to limit boost ramp up. You can see this with datalogging.
So, yes, there is some turbo lag from the hardware of a small 2 liter engine spinning the turbine and compressor. But, a significant portion of this is from software and tuning.
ephone1
189
160
43
West Michigan
Is 3.3t turbos also twin scroll?
PJ Genesis
31
Not sure if my car has had the TSB reflash, but at this point, in the hot summer weather, I wouldn't call it a major issue. Any improvement will be welcome though.
