bluegenesisfl
In an attempt to help others with the learning curve for the SCC/ACC I will list some bits of information about what I have learned in using the SCC/ACC on my 2015 Genesis. The beginning initial comments are basic, but bear with me, the later comments will get more interesting -
Overall this SCC/ACC is really great, but it does have some important limitations.
-I use all 4 bars for spacing, I would be cautious using fewer bars until you are fully knowledgeable in the characteristics of the system.
-Straight ahead driving at most legal speeds the car will station keep its' distance very well. Provided there is a moving car in range in front of you.
-When you engage the SCC/ACC a car symbol will appear on the dash indicator with dashes in front of it. As you are learning, notice as you approach a car ahead of you, when the car symbol on the CC indicator on the dash, comes on. This distance will vary, depending on your speed.
-PLEASE NOTE - If you are approaching a stopped car that is ahead of you (as at a traffic light) as opposed to following a moving car, you lose a fraction of a second until the system spots the stopped car. This makes for some very interesting moments! The Genesis will stop, but it is very sudden and very hard.
-The SCC/ACC seems to be mostly on very good behavior when cars cut in front of you. This depends on the cutting in car's speed. If it is accelerating away the CC barely changes pace. If close to matching your speed the CC will back down to maintain distance and match speed. HOWEVER- if the cutting car is slower the CC will sense that and will hit the brakes, sometimes hard, depending on the closing rate.
-BEWARE OF CURVES - If the road curves rapidly, the CC may "lose sight" of the car in front of you, as it goes into the curve. I have noticed that if you can put a slight turning input to the steering wheel as the leading car moves "out of sight" the CC sensors tends to pick it back up. Then as you are fully in the turn the sensor usually is detecting the car ahead. Constantly curving roads can make it challenging for the CC sensors.
I have more comments I will add later about cars exiting from in front of you and intersections and interchanges.
Hopefully, this will be helpful to someone!
