Midnightsun
Had some time on my hands this morning so I am going through my owners manual. I came across some interesting things.
Engine Valve Inspection
There is a recommendation for valve clearance inspection/adjustment every 96,000 km (60,000 miles) on the Lambda engine only. (V6) I assume this means the V8 is self adjusting.
Vehicle weights.
There is quite a lot of talk about how heavy the V8 option is yet the AWD V6 weighs only 45lbs less than a 2WD V8.
V6 2WD 2,400kg (5379lbs)
V6 AWD 2,500kg (5511lbs)
V8 2WD 2,520kg (5556lbs)
V8 AWD 2,590kg (5710lbs)
Dead Battery.
If the battery goes dead you will need to reset the auto up/down window feature, sunroof, trip computer and climate control system.
Trunk Fuse Panel.
Unusual place to have a panel but good to know they have put one there. Quite a few fuses located there and worth a look in your manual. Pg 7-67 in the CDN version.
LCA. (Lane Change Assist)
I knew there was some kind of system as I had seen it in operation numerous times but did not know what it as called. The LCA is tied into the BSD (blind spot detection) and warns you of a fast approaching car on either side. Nice feature.
ECS. (Electronic Control Suspension)
I thought this was simply tied into the sport mode which made it stiffer which it does however there is more to it than that.
ESC OFF Feature.
This was discussed and fuses were pulled and you name it on the Gen 1 as there was no real way to defeat this. If you hold the ESC button for more than 3 seconds you turn off the esc completely, both engine and brake control.
Feel free to continue this list as there are certainly more items I have overlooked which may be of interest to others.
Vehicle weights.
Dead Battery.
Trunk Fuse Panel.
The ECS controls the vehicle suspension automatically to maximize driving comfort by taking into account the driving conditions such as speed, surface of the road, stoping requirements and acceleration
ESC OFF Feature.
