Some sort of oil/fluid leak?
calgarygeologist
Hey folks,
Just want to see if anyone can potentially point me in the right direction on a leak. I was changing the oil on a 2013 Genesis sedan 3.8L today and I noticed that on the driver's side steering rack there was some oil staining. I'm assuming there might be some sort of oil line seal leak but I'm not familiar with common Genesis issues so I'm wondering what insight the experts on this forum might have. I tried to look at things from the top down and I couldn't see any indications of a leak from the top end. Is this going to be an easy remedy or a lengthy/expensive process?19058
I'm going to assume that is coming from the seals for the high/low pressure lines to the rack but can't be 100% sure. However it doesn't look like a major concern at this point. Best thing to do would be to clean that area up and monitor it from time to time.
Hey folks,
Just want to see if anyone can potentially point me in the right direction on a leak. I was changing the oil on a 2013 Genesis sedan 3.8L today and I noticed that on the driver's side steering rack there was some oil staining. I'm assuming there might be some sort of oil line seal leak but I'm not familiar with common Genesis issues so I'm wondering what insight the experts on this forum might have. I tried to look at things from the top down and I couldn't see any indications of a leak from the top end. Is this going to be an easy remedy or a lengthy/expensive process?View attachment 19058
Can you circle the problem area? Cant really notice oil stains everything just looks dirty
