Spacers
GP123
ny
Hey Guys. i wanna bring out my rear tires a bit, not too much. What size spacers and where can i get them? am i gonna need bigger lug nuts?
adding a spacer moves the rim weight point out on the lug bolt... So changing the lug nut will not help you. I don't know what stress tests were performed on the bolts but moving the weight further away from the base will create stresses and could lead to a lug break.
small spacing is common, and many on this board have used spacers as required for winter tires (a couple of mm spacer is common)...
If you are looking for a significant offset (1/2 inch?) I think you would need to look at changing the lug bolts to beef up the support.
