Spare tire pressure
jarred52
With cooler weather upon us, don't forget to check the air pressure in your spare tire.
My Genesis compact spare says it needs 60 PSI, and in my experience a pressure that high leaks air a lot quicker than a normal tire. So yes, definitely check the spare tire pressure.
I add air to mine every three months. I always find it between 40-50psi
I don't bother checking the air pressure in the spare. I carry a air compressor in the trunk to use as needed.
Not all small air compressors can inflate to 60 PSI.
Never checked mine. When the roadside assistance guy comes he probably has a compressor, I hope, if needed
On the first really cold day there will be a lot of cars at the dealer or tire shop wondering why the TPM is lit up. .
Most can, but it depends how long one is willing to wait. I was checking my wife's (down to 17 psi), and I couldn't help but notice it took a LOT of air to get it to 60 pounds. I can only imagine that inflating that thing from 17 to 60 psi using a small 12VDC compressor would take several hours, since most of them have a 20 minute duty cycle (10 on, 10 off).
Thumbs down! On both my Hyundai cars, I have to flip the spare to get to the valve.
I just bought this tire inflator yesterday at Lowes. I didn't know, but Lowes owns Kobalt.... https://www.lowes.com/pd/Kobalt-12-Volt-Car-Air-Inflator/1000092575 This meets all my needs, AC and DC, inflates to 120 psi, and cost $44.95. As to having to flip the spare, I solved that by buying a valve extender hose by Accu-gage, chek spare, valve extender. Amazon has them. It's a hose that screws to the valve stem and you can then put it up into the trunk to easily check the spare. Found that by accident when I bought my tire gauge. I'm very particular about the tire's pressure and check them often. Lifting out the spare each time just wasn't cutting it.
My spare was about 34 psig last weekend when I checked it. I'll have to get one of those extender hoses for next time.
