Stinger lowering springs installed
SirFrederick
241
43
Canada
Do you have a different vehicle for winter? The color is fantastic and It looks great lowered. I've seen a few pics pop up on instagram. I don't think I could survive with our roads and winters though.
Absintheuphoria
187
43
The rolling with the AWD height is something I've noticed in turns. Seriously considering this for myself. Thanks for the pics!
Antimatter
11
No Genesis Yet!
My main gripe with the G70 is the stock rise height. This fixes problem nicely. Looks great.
GenericUsername
34
Toronto, Canada
That looks incredible; the wrap, and the height! I have a question; correct me if I'm wrong, but I thought you're from Ontario. If that's the case, how do you get away without the front plate? Did you take it off yourself? What was the procedure like to remove the front plate holder if it was installed by the dealer? I wonder if there would be any screw holes in the bumper if one were to remove it :/ Thanks.
OMG70
Master Bruce!
1,312
1,504
LA/OC, California
If its the same as the US ones, there's 3 screws that hold the plate holder onto the car. They are drilled into a black plastic piece behind the grill design. Just take a phillips head screwdriver, remove those, remove the plate holder, and optionally replace the screws in the holes if you want to plug em
Absintheuphoria
187
43
Genesis did a good job with a decent front plate holder for the G70, but it still looks horrendous and I wish I didn't live in a state that required it.
nezro
No Genesis Yet!
Did you get an alignment afterwards? Or you still within factory spec. (I've had lowered cars in the past that didn't like staying aligned afterwards..)
Sid3ways
51
13
I have the same issue, but I don't give a h*ck :roflmao:
Agreed, it has been law in Ohio forever and I have about 4 warnings in my last 22 years of driving. I always have refused to run a front plate. Thankfully though last month they passed a law which will FINALLY remove the front plate requirement which goes into effect in a few months I believe. :D
Toddasaurus
REEEEEEEEEEEEEEEE!!!!!
3,284
4,409
You and me both. I've got my finger's crossed that I don't get a ticket for not having the front plate. If I do, I'll put one on with an off-center mounted towhook plate holder.
OMG70
Master Bruce!
1,312
1,504
LA/OC, California
I've seen a few options for plate holders that tuck away under the bumper with an electronic remote-activated system, but I think it involves drilling into it
CoconutRob
490
63
its my daily driver, drove it all winter long and plan to drive it next winter.
Did you get an alignment after lowering? If so did you have alignment specs?
Draco-REX
186
43
Ohio
I hope he did. ANY time you unbolt something in the suspension (except sway bars) you need to get the alignment checked.
For alignment, stock specs should be attainable with a mild drop like that. If you're looking to fine tune your alignment:
Front camber and caster are not adjustable stock.
Front Toe (0.15):
A little toe out will get you more responsive steering, but the nose will wander more based on the shape of the road.
A little toe in will make the car more stable on uneven roads, but won't feel as responsive.
Zero toe isn't recommended. I used to go with 0 toe, but I found out it's really the worst of both options instead of a middle-ground.
Rear camber, (-1.5). It's within spec and a little more aggressive than stock. But with so little up front, much more than this would be useless and going less to balance the car more is just the wrong way to go about things.
Rear Toe (0.20), you never want to go toe-out. A little toe-in will make the car more stable in turns and I highly recommend it.
