Stock High Beam Compatibility
Jfaden23
Merced
I ordered some ZxE H11B from Amazon because it claimed to be compatible with my 2015 Genesis Coupe...After housing was removed and stock high beams were removed, i noticed that the stock was a two prong plug in, while the H11Bs were a single prong. I messed up. I decided to spend a little extra and go into Oreighlys so i could actually speak with someone and make sure the part I'm ordering is correct, because I can see myself messing something up, either paint or fenders if I regularly pull these light housings out just to see if a part fits. I'm being told part number 9005 is correct and compatible with my coupe, but on this model number comes a 90 degree elbow sleeve at the base of the light, and if i remember correctly I didn't have to unplug an elbow on my first failed attempt...it was simply a bulb connected to a two prong insert. Has anybody experienced this? I would just like to be sure before I take the housing out again if this will in fact fit.
My guess is I would have to go one step further and unplug the existing elbow that I simply do not remember seeing and replace it with the new one?
I hope this made sense...any thoughts?
