strange tremble with noise between 2000 and 2200 rpm, especially on 3rd & 4th gear
kknm1485
Hi everyone,
I have an 09 genesis v8(2k) and notice that when the RPM's hit between 2000 and 2200 rpm, especially on 3rd and 4th gear, there is a strange noise with tremble that sounds like it is from right underneath back seat. Not sure where exactly it is coming from. Strange thing is that I can't feel it on other gear. All I can say is strange reaction at exactly between 2000 and 2200 RPM. Once I go above or below 2000 RPM's the noise stops.
Anyone else having this issue? Anyone have thoughts about this?
Thanks in advance for your help with this.
Re: strange tremble with noise between 2000 and 2200 rpm, especially on 3rd & 4th gea
There is a TSB to cover the rear drive shaft noise, which may be what you are hearing. Check the manufacture date of your car in the drivers door jam to make sure it was built before the dates below. If your vehicle is covered by the TSB and the dealer claims the noise is normal, you should show them the information below.
Group: CHASSIS
TSB Number: 09-SS-002
Date: AUGUST, 2009
Model: GENESIS SEDAN (BH)
Subject: REAR HUB AND DRIVE SHAFT ISOLATION WASHER INSTALLATION PROCEDURE
DESCRIPTION: Some vehicles may exhibit a driveshaft “snap” noise when the vehicle is driven in forward or reverse. This bulletin provides instructions on installation of a washer between the rear hub and the driveshaft (both sides) to repair this condition.
APPLICABLE VEHICLES:
  • Model: GENESIS SEDAN (BH) (4.6L and 3.8L Engines)
  • 4.6L Engine Model Year: SOP 2009 to Feb 16, 2009
  • 3.8L Engine Model Year: SOP 2009 to May 12, 2009
WARRANTY INFORMATION:
OP CODE: 51755F00
OPERATION: REAR HUB BEARING WASHER ADDITION
OP TIME: 1.3 M/H
CAUSAL P/N: 52730-3M000
NATURE: N29
CAUSE: C24
Thank you for your answer, but the manufacure date of mine is April 15, 2009 :(
I have the same, but it normally starts about 3800-4K RPM and is gone by 4.5 to 4.7. Gear doesn't matter, nor the road.
Normally after 15 minutes of driving it seem to disappear.
