Struts?
Zod
My local indy shop can only find OEM front struts. Does anyone make a performance strut for these cars?
What year and model/version is your car?
How do I tell? I've only had this car a few months and it's my first Hyundai.
Take a picture of the center console and upload it. Models can be discerned by the buttons just below the shifter.
Ok
Nice! Std. suspension, only the 5.0 ultimate had active CDC.
My man! I just want to stiffen things up like my BMW 87 535is
Anyone experiencing squishy squeak noises from from struts going over speed bumps initially in cold weather? Noise does disappear after some driving. I’ve replaced front struts for this issue but it has returned 1 year later.
Were the upper mounts replaced too?
Invoice says replaced l/r struts tops and mounts. What was done / parts (qty)
(1) shock absorb assembly 54605-B1250
(2) Insulator asst-st 54635-B1000
(1) Strut Assy-FR,RH
Cold weather would suggest the Ideal Gas Law
Temperature and pressure vary directly. I'm assuming they operate along these lines:
The Bilstein name graces not only monotube gas pressure shock absorbers, but also single and twin tube McPherson strut style suspensions. Utilizing the same technological design advantages as their monotube gas pressure shock absorbers, Bilstein’s twin tube strut assemblies are designed to withstand maximum loads while providing high durability. Both Bilstein shocks and struts are built to meet the fitment and performance needs of specific vehicles. And their patented design reduces the need for a compromise between ride, handling and control. The rising rate valving of the Bilstein shock absorber provides the necessary damping to react quicker to road conditions without sacrificing ride comfort. This combination of valving and high-pressure nitrogen gas keeps the tires in constant contact with the road helping to enhance safety through improved control.
