Studs on Genesis emblem fitting 2015 "H" G80
Hugh185
No Genesis Yet!
Hello to everyone,
I have a G80 2015 with the H on the trunk
I plan to replace it with a genesis Badge, do the studs on the genesis emblem fit inside the hole left by the H or do I have to plan to remove the studs and only rely on the adhesive ?
Thank you,
Hugh
Hello to everyone,
Thank you,
Hugh
They don't line up. You'll have to cut them off.
There are diy posts to do this
The rear Genesis badge I had to buy to replace the buggered up one on the car when I purchased it had no studs on it. The adhesive is adequate.
OK I will do thank you like this I will not have any psychological shock :ROFLMAO:
I would also add some silicon or other water proofing material to the under side of the trunk lid to seal the holes behind the emblem to prevent leaks. Just as a precaution, not a must do.
