• 🔍 Like our community? You can tell Google to show you results from this site more often. Just Click Here and then click the empty checkbox on the right side of our name.
Sunroof malfunction
As an Amazon Associate we earn from qualifying purchases.
vmi9d3
Odenton, MD
I searched the forums but couldn't find any leads...just recently my sunroof won't close all the way. I have only observed this when it is in the full open position vice tilt. When I use either the sunroof or sunshade control lever the glass slides forward but will stop at about 4 inches to close and slide back a few inches. After trying several things to get it to close, it appears in consistently closes when I hold either lever until it closes all the way. This doesn't happen every time either, seems like it is about 50/50. I looked in the track and it appears very well greased and nothing appears to be blocking the glass from closing.
Has anyone else observed this? Should I do a reset as per page 3-42?
Thanks.
G80 - 2018
I had this on my Genesis Sedan. It corrected itself. A search produced these threads:
Thanks for the info. I will try the reset this afternoon, and I am taking it in for routine service tomorrow, I will ask them to lube it up too. I am not too sure a lube will do much, the motor doesn't appear to be strained, I don't hear anything, and I can visible see grease in the tracks. Maybe there are some spots that need lube I can't see.
Update: while at routine service, I was unable to replicate the issue for the tech, of course not, it would have been too easy. I asked if he could grease it up. He claimed he would, no indication on the paperwork he did, but since then it has been operating normally. Fingers crossed.
