Suspected tire noise
Rob C
Womp, womp womp / chucker chucker chucker noise at 60+ mph, can't tell witch corner it is coming from, about 2000m on tires, had it in the air and all tire's look good.
Maybe put it on a lift and take a look. You may see a flat spot, lump, or a screw in it.
Thank for reply, but did you read the whole post??
You said they look good but gave no indication of how you looked at them. One a lift or sitting in the driveway? Did you pull them off the car and check balance?
Reread HAD IT IN THE AIR
Take it back to the shop you bought them from. There are a few things that could cause that. Tires are out of round, flat spots due to sitting in cool/cold conditions, road debris impact, weren't properly balanced, alignment
