Switching between Media types
RoyG70
Manassas, Virginia
It does not appear that you can easily switch between two different connected media sources. For instance I have an iPod connected to the media port, and I have my iPhone connected via Bluetooth. I have to disconnect from Bluetooth first before it will play the iPod, you cannot just switch back and forth between the two. Doesn't allow you to fast forward and skip songs/podcasts on a Bluetooth device either. Wondering if this is how it is working for others too. Just a little annoying since my previous, much less expensive, car could do all this. Thanks
Are you pressing the media button? When I do that the menu pops up and I select what I want. I often change between my Bluetooth and USB.
I can FF/Rew on my Android via bluetooth.
Thanks, figured it out. I was clicking the menu button on the Bluetooth screen instead of just hitting the Media button again. Duh. To clarify the FF/RW, it only does not work with an iPhone connected via Bluetooth. It will only skip tracks.
