Taillight issue HELP
Chrisjones1389
So I have a 2015 genesis sedan with led lights and today the rear passenger tail light stopped working. I checked all fuses and checked housing and wires. All other lights work but that.
Anyone had this issue or know a way to fix??
Take it to a qualified service shop to have the control module tested. It's probably the light though.
The issue is probably the common taillight harness wiring breaking issue the 2015 and 2016 models has. The wires break due to too much tension when trunk open and closes with wiring harness and bracket in the original factory location in the trunk. The Hyundai TSB fix is to repair the broken taillight wires and then relocate the harness in a location without tension when
This thread will help. Easy fix if you can splice electrical wires. Post #8 explains the TSB and how I repaired my taillight wires.
