telescopic steering wheel problem 2009
James Croghan
Just purchased new (used) 2009 sedan. Telescopic steering wheel appears to have issues. Anyone else experiencing this?
Limit switch failure is a common problem in 2009 cars, and affected the tilt steering as well as the power seats. A dealer may charge $500 or more to fix.
If you have the "easy exit" feature enabled, disable it.
There is a "hold the control for 10 seconds trick" that may work for you:
DIY thread when it doesn't:
TSB:
TSB:
I had the same issue with my 2011 4.6 and it worked. Thanks !!!!!!
i have the same issue it will only telescope if i push or pull it a lil bit. will be diving into the steering column soon to try and address other issues
