This little light is out in one of my headlights
Jimmythecdawg
It’s the small one in the bottom picture is lit but the one on the other side is out. If it’s not a setting, is there an easy way to get it replaced? E7EE083E-E689-496F-9051-599BCBD7C101.webp62FCFD6B-7C0D-440C-9726-33ECC8D2A02E.webp
^IIRC you can just access the back of the light (once you take the circular dust covers off the rear of the headlight) and pull it out. I got sick of replacing mine as they kept burning out, and ended up removing the bulb and just putting the socket back in. The look was cleaner IMO, but may not be a desired solution for you.
EDIT: I upgraded to R-Spec headlights after that and all the lights worked well on those.
When I had my Genesis I replaced the small lights with a high quality 194 LED bulb. never had to replace again.
