• In the 1980s and 1990s we used AOL and Usenet. In the 2000s there were forums and message boards. In the 2010s - and until the very near future - Facebook and Instagram. Something new is coming for Genesis owners... Become an early adopter of what's next by SIGNING UP HERE. Your email address will not be sold or used in any way other than us communicating more details as we prepare for launch - and we will not communicate often.
Tilt ,Telescopic ,Wheel
MHT
35
I lost range of motions to my tilt wheel a month after purchase. I see where most of you that had the tsb performed had a limit switch replaced. According to my service order to make the repair the motor to column tilt was reinstalled.
If you are still having problems after the limit switch install you may want to inquire about the motor to column tilt reinstall.
vega
2
Genesis G80 Sport
I have been waiting more than a month for the limit switch. This must be a huge problem, as the ESC unit was received in less than 3 days.
MHT
35
When I called my dealer and inquired about the TSB requiring the limit switch replacement, they had the limit switches in stock. The repair to my car was done by reinstalling the tilt column motor. My paper work does not referenece a TSB being performed nor does it list any limit switch replacement. They did say the repair was intense.
They also performed Recall TB4 which involved the install of spacers, 1
part number 00305-11296 propeller shaft B.
MrB0462
I was at my dealer today and they had the replacement switch in stock BUT...... there was no spot to install it as my car did not have a separate switch. It is integrated into the steering column and the whole steering column needs to be replaced, not just the motor.
Late 2010s will require the replacement of the steering column not a switch replacement. The dealer can contact Tech Service support for full details. Column ordered today new appointment 2 weeks from today.
MHT
35
The service department repaired mine by reinstalling the tilt column motor.
MHT
35
I'll see what they do in 2 weeks
TSB
Group-Electrical
Number-10-BE-002-1 (updated)
Date-April 2010
Model 2009/2010 Genesis
Production Range-April 25,2008 - March 12, 2010
Tilt Limit Switch, Telescopic Limit Switch and Tilt motor are located on
the steering column. They are not intergraded into the steering column as shown in diagram of repair.
My car was built Feb. 18 ,2010. Was your car built after March 12,2010 if so that would explain a possible intergration of the limit switch into the steering column. Just curious..........
MrB0462
TSB
Group-Electrical
Date-April 2010
No February 1, 2010
MHT
35
No February 1, 2010
Ok I see what happened. Thank you and good luck with the repair.
I am pleased with the repair and the great service I got and I hope the
same for you.
kayroe
The build date of my 2010 4.6 was Nov 2009, but when the techs tried to replace the tilt limit switches they couldn't because of the integration of parts. The whole column has to be replaced. I'm waiting on the column to come in at any time now.
