Tinting tail lights
RGenny12
I've been looking up how to remove the tail lights so they can be sprayed/applied with film but I can't find anything on it. While we're at it, is there one you prefer over the other? Thanks!
To remove the tail lights...look on the far left and far-right corner inside the trunk...there is a little cover that you must take off once you take that off there are three 10ml bolts inside. Take that off and you should be able to remove the outer tail lights. To remove the inner lights (reverse lights), you have to remove the paneling on the back side of the trunk lid to access the bolts.
As far as tinting goes, Ive always used vht nightshades in the past with great results. Mind you this was on cars that had cheap tail light replacement if you messed up... as ours are definitely not cheap to replace.
Anyone had any luck with film tint?
