Tire pressure thoughts
pmckechnie
Matthews, NC
Thread starter #1
I have a 2018 G80 and love it. It is quiet and smooth. I took it to the dealer for a map update and it didn't go well. It now has NO GPS. Well I have had a courtesy car for over a week now. It is also a 2018 G80 like mine. Same engine, both RWD, both have Mich tires. I noticed that the courtesy car seemed quieter on the road and smoother over irregularities in the road. The only reason I could come up with is I have always run 33 psi cold tire pressure. The courtesy car has 28 psi cold tire pressure. Now my question.
I also have a 84 Mercedes 500SEL that calls for 28 psi cold. Now I know it has different tire size than the G80 but do you think it would hurt to run 28 in my G80. I know that it may loose a little MPG and possibly some high speed handling. It could cause more tire ware on the outside edges. I can live with these issues to gain the quietness and smoothness.
What are your thoughts?
EdP
Supporting Member
SUPPORTING MEMBER
1,274
39
48
CT
#2
You can probably get away with it in NC, but I'd not try going that low in a cold state. When the temperature gets really low, so does tire pressure and it sets off the warning.
You already listed the potential problems of low pressure and yes, there is a cost to it. Another poster mentioned the same thing with a dealer loaner. I wonder if dealers do it to give a more plush ride to perspective buyers taking a demo ride.
The government mandated pressure warnings to save on energy from under inflated tires so watch out that Greenpeace is not following you. FWIW, I run 34 pounds. I don't want to compromise handling.
Mark_888
49
48
#3
The recommended tire pressure is set in conjunction with various testing for handling, braking, rollover tendency, etc for that specific car and its suspension. Lowering it to below the recommended value will adversely affect those characteristics. In addition, it would likely adversely affect the life of the tire.
If you do run your tires a 5 PSI below recommendations, I would not advertise that fact even to friends and family, since it could back to haunt you in a lawsuit over a traffic accident.
JimInNashville
#4
Reducing tire pressure to 28 in that vehicle is not wise at all. You may experience some additional smoothness, but you'll hear a lot of squealing on sharp turns or in parkades, your braking distance will be increased and your cornering and handling decreased. If anything, run them at 36 instead of the recommended 33.
That said, I want to emphasize that Genesis quality control for NVH issues is not great. I had two identical 2015 Genesis 3.8 HTRAC sedans, and the first one was much quieter on concrete roads than the second one. I can't get Hyundai to do anything about it (yet).
pmckechnie
Matthews, NC
Thread starter #5
Just to find out, I set my tire pressure to 28 psi for about 500 miles. Sure enough, it was smoother and quieter on rough roads.
Otherwise, I could not tell any difference in the way it handled.
I then raised the pressure to 36 psi. I can feel the bad roads more, but no difference in the smooth roads.
We are going on a 3000 mile (+/-)trip this month and will see how it does. I expect the mpg will go up some. Not that it is an issue.
Scooby
5
Wake Forest NC
I can't say for a luxury car tire... but on my Jeep that has 37" tires load range D and requires 65lbs. I run 32 lbs on the road and 12 lbs off road. The ride and handling characteristics are much better at 32 lbs. Of course it's a truck tire so even deflated there is very little buldging of the side wall.
I would suggest dropping in 2 lb increments as you may find that 28, 30 and 32 lbs run very similar and you'll be more in line with the tire spec.
Good luck!
pmckechnie
Matthews, NC
Thread starter #8
Update. We took a trip going from NC to NM and across Texas from El Paso to Waco, then to Brownsville, Corpus Christy, and back to NC via
the southern route to Flordia and up to NC.
Tire pressure set to 36 psi cold which went up to 39-40 psi hot.
Ride was quiet and smooth on the good roads and noisy and rough on the bad roads.
What I liked about the higher pressure was the MPG.
We drove 4834 miles and averaged 27.9 MPG for the trip.
Lowest was 24.1 at 80 mph and a strong head wind. It was almost all highway.
Best was 30.8 at 75 mpg most of the time but had some site seeing excursions also.
I am sure the higher pressure helped. However when we got home I drooped the pressure to 33 psi
and can tell a big difference in noise and comfort. I will be using 33 psi from now on.
Another observation was that the calculated MPG and the car computer MPG were very close
at +/- 0.3 mpg. One fillup was off by +1.8 in the car but we were in a traffic jam for quite a while on that tank.
Over all we had a great trip. I love the G80 and can't wait to take the next trip to who knows where.
EdP
Supporting Member
SUPPORTING MEMBER
1,274
39
48
CT
#9
Decent mileage given the size of the car. The Genesis is the most comfortable car I've had for long trips.
On the highway for a time I get up to about 41 psi.
