Touch screen issue
Cowboybob52
Back up camera works but then screen displays “Genesis Badge” and is unresponsive to any attempt to navigate to anything else.
Sounds like the head unit is confused. I would try a reset.
How do I reset it?
Thanks for the reply!
How do I reset it?
Look at the front panel. Should be a small hole where you can insert a paper clip or ball poit pen tip. Going from memory, it is below the CD player.
Thanks……. I’ll check it out!
No holes anywhere on front panel!
Will it reset if I disconnect the battery?
Found reset hole and tried it.
Did fix the issue.
Any other suggestions?
Thanks!
Reset did not fix the issue.
