TPMS - How To Create A Baseline Reading
addysdaddy
I could not find a way to create a "baseline" tire pressure on my G70. On my wife's GLC300, you cold fill the tires to the desired pressure and go into the pressure reading menu - where you then hit a "set" button to establish a baseline. Should the pressure drop 3-5 lbs or more from that mark, you get an alert. There doesn't seem to be a comparable function on the G70. The manual also doesn't say how many lbs it takes to trigger an alert. Can anyone clarify?
NLJ
1,060
Vancouver
Don't think there is. On my Mitsubishi, a 4psi difference between tires will cause the TPMS to go off.
addysdaddy
So there is no way to create a baseline reading AND we don't know how much the pressure loss is before tripping the alert? Seems surprising for such a well thought out vehicle.
joschneider
G70 Member
1,001
1,238
Las Vegas, NV
No way to set a baseline. Pressure loss should be 4-5 lbs before alert but I don’t know that 100%. The default baseline is what is set for the load and available tires and can be found on the door. Since that was well thought out, I don’t think they want customers creating their own
EdP
Supporting Member
SUPPORTING MEMBER
6,489
3,059
Parrish, FL
addysdaddy
Mine trip at 29 psi on my last 3 cars. Setting a baseline would be OK if there was a minimum and you like to keep pressure at higher than the sticker. The government just says you have to be over a minimum pressure and they comply. I don't know what the exact spec is. If allowed to set a baseline low, someone will set it at whatever makes the light go out and never bother to add air.
Reality is, 98% of drivers have no idea what they should set as baseline so Genesis keeps cost down by not having it.
Well in a weird way I understand that logic - haha. Thanks for the explanation. Set my pressure to +1 over what's on the door.
nellie1289
213
43
Portland, Oregon
On this topic my low pressure light came on today as I left outside and it was cold. 29psi. I drove around and it came back to 32 as it warmed up. But light won’t go out. So I filled all tires to cold 35. Right front light still on. Do I need to drive it farther. I did a hot lap around hood to see if it would go out. Now all tires are at 36 and light still on.
EdP
Supporting Member
SUPPORTING MEMBER
6,489
3,059
Parrish, FL
Mr. Incredible
SUPPORTING MEMBER
2,890
1,246
Genesis G80 Sport
addysdaddy
NHTSA regulations require the system to trigger if there is a 20% drop from recommended pressure or a difference of 20% between the lowest and highest readings of the 4 tires.
so at 36psi the system will trigger when any tire drops 7psi or there is a 7psi difference between the lowest and highest readings.
Good to know - thanks for that. I'm assuming the recommended pressure is what is written on the inside of the driver's door.
Toddasaurus
REEEEEEEEEEEEEEEE!!!!!
2,668
3,308
Low pressure light still on today?
Mr. Incredible
SUPPORTING MEMBER
2,890
1,246
Genesis G80 Sport
pmckechnie
315
72
Matthews, NC
One thing that has not been brought up is the pressure change with the temperature goes up and down.
If you set your pressure at 36 psi and the temperature is 40 deg at 7:00 am, and you go to work and when you get home at 5:00 pm and the temperature is 80 deg, then your pressure in the tires is now 40 psi.
In other words, for every 10 deg of change , the temp will increase or decrease 1 psi.
So What should I set my tire pressure to?
One thing for sure, I am not going to change the tire pressure 2 or 3 times a day.
Mr. Incredible
SUPPORTING MEMBER
2,890
1,246
Genesis G80 Sport
pmckechnie
315
72
Matthews, NC
Thanks Mr. Incredible. That is what I was trying to get across.
Also keep in mind that if the car is outside and the sun is shinning on one side, that side will
need a lower pressure than the other side. How much, I don't know. I use a temperature sensor
that you just have to point at the tire to get the temperature.
EdP
Supporting Member
SUPPORTING MEMBER
6,489
3,059
Parrish, FL
Mr. Incredible
SUPPORTING MEMBER
2,890
1,246
Genesis G80 Sport
EdP
Supporting Member
SUPPORTING MEMBER
6,489
3,059
Parrish, FL
Pedal Commander
