TPS Gremlin
Flex59
I love my Genesis w/Tech. Pckg and have owned it since 08/08 without a problem. But, for the second time, the TPS shows up telling me that the rear passenger tire is low. Now, the first time it happend - about a month ago - I went and had it checked and they were all the same pressure (I replaced regular air with Nitrogen).
Now, today again I turn the car on and, low and behold, the TPS comes on with the same rear tire. The tire looks fine and the car rides great.
Does anyone know how to remove the TPS from the screen since the tire is fine? Or should I take it to the dealer to see what can be done?
Flex59
I had that happen once on one tire on a very cold day. Hasn't happened since. I assume you know that you loose about 1 psi for each 10° F below 70° F.
Actually, I took it to check and it was low, the TPS system was 100%. I guess I have a small leak on said tire. I'll try and have it checked this Saturday where I had the Nitrogen done. Thanks guys.
Still happy as can be with my Genesis - LOVE IT!
Flex59
