Transfer Case Fluid for 2015 5.0L
eastcoastgenny
I have come across this other thread regarding a drain/fill of the Transfer Case - which is a little picky to service given that its sealed and suggested to be a "lifetime" part. There is fantastic discussion and help within, but it seems that some of the particulars relate to the newer generations and are not specific to the 2015's.
I'm wondering if any knows what the Transfer Case oil that you would use on the 2015 models is?
Shell ATF TF0870 is what needed. However, any TF0870 rated ATF fluid should work. TF0870 is very expensive ATF fluid that is also used in BMW tranfercases.
thanks so much for this - don't mind that its expensive if that's what will work!
