Transmission & Differentials
alii143
I am willing to change the Transmission & Differential fluid for my Genny and I am honestly confused about the following and just dont want to mess up the car
1) correct me if I am wrong, do I need to drain and refill the Differential fluid multiple times or one time is enough. And what is the best fluid to use ? Amsoil ? Do I need to add Slip Lock or Amsoil alone would do the job.
- And if I will go with the factory fluid to i need to add Slip Lock too? Or any other additives ?
2) Regarding the Transmission Oil, again.. Amsoil will do the job? And if I will go with factory oil, do I need to add any extra additives?
- Regarding the drain and fill process, do I need to do it multiple times or just once. If its to be done multiple times, what's actually the process ...
For the Transmission Oil Change, Following the same exact steps of this video will keep things safe or there's something he's missing:
We had chat on reddit.
First off, how many miles on your G70? I wouldn't worry about the transmission service until 60 to 70k miles, and when you do it do a 2 or 3x drain & fill w/ driving through the gears and putting a couple hundred miles between each drain & fill.
Some do a single drain & fill then do another 10k miles later, IMO it really doesn't matter too much but I think I'd like to get a majority of fresh ATF in the transmission sooner than later. @Volfy mentioned in another thread that Valvoline Maxlife ATF meets the Hyundai SP-IV-RR specs. I've used Maxlife in a couple vehicles, and it's worked well (A Toyota Tacoma and Infiniti G37). It's less than $30/gallon so makes the drain & fills much more affordable. Here's that Maxlife spec sheet/info
If I were doing the drain & fill the first time I would probably want to remove the pan, this will drain more fluid and you'll be able to clean out the pan and the magnets.
When doing the rear differential (I have a RWD so I can't comment on the front if you have AWD) it's a very simple drain & refill. I just backed my car up on ramps and drained into a marked bucket, it drained out a bit less than 1.5 qts and I filled 1.5 qts back in. I used Royal Purple, has worked well!
The car is 40k now, and it is RWD. I am aware the Transmission fluid to be changed at 60k miles as per the owners manual. And what do you think about Amsoil ATF, would suit the SP-IV-RR Specs?
And thats what I was thinking, to perform full oil change and just drop the pan. But some genesis owners somehow wouldn't recommend that for some reason. Thinking about it logically, I dont think it will cause an issue if you will just drop the pan and perform full transmission oil change at once
If you can drop the pan and clean it along with the magnets that should be in the pan that would be a plus. You should drain a bit more fluid that way. I'm pretty sure you have to buy a new pan that comes with a filter if you want a filter change. I haven't heard that you can just buy the filter, but could be wrong there.
Amsoil ATF is fine. So are a lot of other commercially available name-brand ATFs that list being compatible SP-IV-RR. New fluid is infinitely better than 60k old ATF.
FWIW, there is really no such thing as "full" trans fluid change. See here: Serious Transmission Jerking/Knocking noise when accelerating
I do get your point but as per your experience, would dropping the pan and perform the fluid change would cause any issues rather than just changing it on intervals would be better?
The main advantage with the pan drop is cleaning the magnets and the pan, plus you get a bit more fluid out. Since you can't just get a new filter without buying a whole new pan (that I'm aware of) at least you can check the filter. I've done a few "lifetime fill" AT servicing and have yet to see a dirty filter so there's that 🙃
I would think for the first service I'll be doing a pan drop and maybe just drain and fills thereafter (like 50k miles later).
"Better" is all relative. Just draining and refill without dropping the pan is definitely better than not doing anything at all. For a lot of folks, who don't drive their G70 hard, that might be fine to get you over 100k miles. Swapping in a clean pan with fresh filter is better still. There are no hard and fast rules when it comes to vehicle maintenance. Usage and operating conditions vary widely and should be factored into you decision making.
That said, if you are going to go through the exercise of changing the ATF yourself, R&R of the tranny pan is not really that much more work.
