Transmission fluid change
lee polowczuk
I am approaching 90 k on my 2015 Equus. Do you change the filter or just drain and refill. How much fluid for either procedure. Thanks
I changed the pan + filter @ 60K. You're able to get close to 7qts drained when you drop the pan.
A drain/fill will get you < 3qts drained.
Had the pan and 7 qts at 100k. There was a perceptible change when the car would downshift from 7th to 6th. That’s gone now
