2011 4.6 Genesis Sedan w/144,000 (approx)
When at speed in top gear on the highway when passing... If I step on the gas and cause the engine/trans to drop into a lower gear to accelerate to pass, all of a sudden the engine races (to around 4K) and does not recover. What does that mean?
This has happened multiple times lately and I've tried to diagnose the exact situation. Long story short, it seems like the tranny drops down into a lower gear to pass (I think maybe two gears down) and if I let up on the gas it still maintains in the same gear and at high RPM. That said, I even pulled over behind slower cars and try to let the syatem recover, but the engine stays at high RPM in the lower gear. It seems the only way to reset the situation is to pull off the road and turn the car off. Then the system resets and things seem to work as normal. But when I get up to speed again and force the situation, it will happen again. So, in order to get home when on the highway at reasonably high speed 70, 80 and 90 I just have to be gentle and don't make it drop down to a lower gear for passing.
Second, I have pushed the tranny at lower speeds around town and it works fine. It will drop down to a lower gear and recover.
Yikes, I'm worried I can't take this thing on road trips. This has happened on the last three road trips.
Your input is appreciated,
I like my beast.
I like my beast.
