Trickle Charger
Gents
My 2020 G70 will be idle for few months, I want to connect a battery minder/trickle charger. I looked under the hood and found the fuse box, inside their was a connection with a red dot, I assume that this red dot wire connection is the positive post that I can use for the red cable clamp, but I did not see a location marked negative outside of the fuse box. Can you please provide some guidance in making the battery minder connection. Thanks
Why not use the factory ground post (#4 in the images)
Battery minder trickle charger is a good charger. I have several I use around the house as well as on my riding mower. If I’m driving my other car and leaving my Genesis is the garage for a while I use my battery minder on my Genesis to keep the battery topped off. They work great at keeping the battery topped off and sulfate free on the battery plates which should extend battery life.
Friend of Mine spent six months of summer in Wisconsin. Used Battery tender on his Chevy that he left in Florida.
Car STARTED RIGHT UP when he got back to Florida.
