Truck opening strength question
JimmyTrom
Hi, I have a 2015 Genesis 3.8 sedan and wondering if there is a method to increase the lift force of the
counterbalance springs or air cyclinders that assist the truck lid.
Its a PITA to pop the truck and it disingages the latch but just sits there.
Its a weak strut in the trunk. See: Trunk Lid Self Opening.
The aftermarket part I installed is Strongarm 6926 (got it from rock auto) and the trunk opens beautifully. Not as violent as the B1010 struts and much easier to close the trunk. One thing I noticed is that the aftermarket part had a thinner rod compared to the existing B1000 strut, but I dont think that will be an issue since the B1000 struts are rated 22lbs and the Strongarm is rated 45lbs. Worst case I can always install the original strut.
THANKS!!!
BTY, got any advice concerning installation?
THANKS!!!
I haven't done this to mine yet. It would be a good idea if you haven't done the trunk lid harness tsb to knock that out while replacing your strut. You will have to replace the strut on the right side instead of the left one like they show in the post.
I've replace my trunk struts twice - they work for awhile then dont.
O man! What part number did you use? I'm guessing they all just suck huh.
