Trunk lift support for 2011 Genesis Sedan
desertdoc
Has anyone located and replaced the trunk lift support for the 2009-2012 Genesis Sedan? Looks from the parts diagram that there is only one and it is on the left-hand side, but I cannot seem to locate any info on how to get to it to replace it.
You have to take the trunk mat and “floor” out so you can see the spare tire. Then you have to pull the molded carpet side walls of the trunk away from the car towards the middle of the trunk. They are secured by a little push retainer right behind the tail light. Pop them out and pull it away. You can access them there to replace.
desertdoc
if you would not mind could you post pictures of the location after you removed the carpeting.
desertdoc
Yeah i can take pictures of the retainers and bolts you have to take off to pull the sidewall away to access the trunk supports. To be continued...
