Trunk Release Not Working
Zoom
Gulf Coast
I am locked out of my trunk. I replaced the fob battery and also tried the the inside release switch. Nothing. Any help appreciated.
2012 Genesis 3.8 sedan
Try the mechanical key. That should work when all else fails.
Yes thanks that works,. The fuse that is installed is 30A for the trunk module; the owners manual says there is another one for the release solenoid, but there is no fuse present in either fuse box for that.
Looking at similar questions across the Web, a "valet lock out" button in the glove compartment is mentioned. I never knew I had one since it is not visible from the driver's seat. You have to open the glove compartment and look up under the lip where the trim pad meets the door. I must have pressed it while rummaging in the glove box this morning. Pushed it in to activate the remote features and all is well.
I did the same thing a few years ago.
