turn off Apple Play?
Philip2
17
Please don't asked me for an explanation but my daily cell phone is a "dumb phone". I also have an iPhone seven,primarily for podcasts and occasional Internet use.
When I plug my iPhone into the USB port while driving to listen to podcasts, it turns on Apple play which then automatically turns off the Bluetooth connection to my dumb phone.
I see no way to default back to my dumb phone. There is an Apple play window on my iPhone where my Genesis comes up but when I click "ignore this possible connection", it still opens up into Apple play. Maybe this page is for Wi-Fi or Bluetooth only.
Anyway do you see any method to continue my dumb phone on Bluetooth while listening to iPhone podcasts? The only way I see is to connect the iPhone into the phone plug rather than the USB port but then my phone won't be charging.
I never really use Apple play so is there any way to remove it or turn it off completely from my iPhone, and if so would that solve the problem.
KevinK
You should be able to go into settings on your iPhone and turn off CarPlay. Go to Settings, General, and then CarPlay to remove your Genesis connection.
Mr. Incredible
SUPPORTING MEMBER
3,015
1,335
Genesis G80 Sport
Philip2
17
on the phone, go into Settings --> General --> carplay. click on the car, and then choose the "forget this car" option.
then when you reconnect to the car don't set it up, and it won't connect to carplay, only "USB audio" as if it was a flash drive.
as per my post- I did this (I said Ignore- but it may have been forget) but it still auto connects to apple play and shuts off my dumbphone. I think this option turns off the Bluetooth connect only, not the USB.
Alfer
272
63
USA
Turn off CarPlay
  1. Before you get in the car, open the Settings app.
  2. Tap General > Restrictions.
  3. Select Enable Restrictions.
  4. Enter a passcode.
  5. Repeat that passcode.
  6. Toggle the CarPlay switch to Off.
Philip2
17
I found this "restrictions" page on my IPhone 8 , it is not on my Iphone 7. It was successful on the I8- thanks- it works.
Pedal Commander
