Turn off Beeping
TerronTech
Hello, I'm a new G70 owner. Is there a way to turn off the beeping sound when you lock/unlock the car. Its getting annoying. Any help would be appreciated. Thanks.
CVODON
122
43
Went outside and checked mine to see if it beeps. It does, Never noticed it before. Heavy stress in your day?
PMCErnie
Ancient ‘steemed Member
4,431
548
Richmond, VA
Odd, it’s is a horn beep, or an electronic chirp?
Mr. Incredible
SUPPORTING MEMBER
3,310
1,545
Genesis G80 Sport
lock and unlock is an electronic beep. been around since 2005 or so on most keyless cars.
should only beep when you use the fob or button on door to lock or unlock, the only other time it beeps is when you are near the trunk for the touchless open feature (if equipped) which can be disabled in the dash settings. or if you have the motor running and walk away from the car with the keys.
PMCErnie
4,431
548
Richmond, VA
should only beep when you use the fob or button on door to lock or unlock, the only other time it beeps is when you are near the truck for the touchless open feature (if equipped) which can be disabled in the dash settings. or if you have the motor running and walk away from the car with the keys.
Thanks, I know. I’m attempting to get the OP to reply.
Qship
40
Ontario Canada
In my 2010 you can turn the chirp on and off from within the infotainment settings under "Car" info>Settings. You can set the doors to auto lock by speed or in drive, auto unlock, turn the chirp on and off etc. It wasn't called chirp or beep or anything like that though. It was something along the lines of "lock sound" or something similar.
jfgenesis
nothing to do with the beep, but when you set the car settings to auto unlock when you shut the car off, it doesnt do all the doors and the trunk, it only does the driver door.. this is aggravating becasue 9 out of 10 times when i get out of car i am grabbing somethign out of the back or the trunk on my way into the house.. and have to go back, open up the driver door, hit unlock... any idea why they dont allow for auto unlocking all doors?
Qship
40
Ontario Canada
Mine does all doors.
All doors lock at 20 km/h. All doors unlock when put in park. I had to set it in the infotainment settings. I have a 2010 3.8 Tech package.
EdP
Supporting Member
SUPPORTING MEMBER
8,460
4,493
Parrish, FL
Check your setting. My G80 is set to unlock in Park and all doors unlock. Doubt yours would be different. OTOH, your present setup can be a good safety situation if in an area of concern.
Mr. Incredible
SUPPORTING MEMBER
3,310
1,545
Genesis G80 Sport
this is a setting within the dash options.
my auto unlocks all doors because I set it that way, by default it only does drivers door. All of this is in your manual.
