UK Spec Genesis
Jasmeet16
Hello Everyone
The UK spec Genesis was the early 2nd gen version sold in the US. Which is a 3.8 RWD version.
However, there are a couple of questions I have to see if parts could be swapped over from 2017 version [facelifted] to 2015 version
This is the headlights, I do like the LED version, but not sure if this is as simple as swapping the old for new
Also is the screen. UK spec did come with phone projection but on a 8" screen. I do like the idea of the larger screen. Again I don't know if it is a simple swap over. Although I will need to modify the screen plastic surround
Finally is Hyundai Genesis using GDS software for diagnostics etc?
Thank you for your help
Just a further follow on question
The coating on the light switch is coming off such that the hard plastic underneath is exposed.
Is there any way a coating could be re-applied, I am thinking like K2 Plasti Dip Clear coat?
Thanks in advance
