Unknown electrical issue
2012gen38
I have a 2012 genesis 3.8 that has issue of stalling (at least I assume its stalling). The car has been sitting for about 5 months and I don't have much information as to what symptoms it was experiencing prior to it's sedentary state. What I know now is that I can start it when it is jumped, it will drive fine for a second and then everything will shut off. I checked the DTC and I have a bunch of codes related to the transmission. Electricals are a bit out of my wheelhouse so hopefully someone on here can help me decipher what it is I am looking at.
Car Scanner ELM OBD2
DTC report
Selected brand: Hyundai
VIN: KMHGC4DE1BU142898
============1==============
P0973
Raw code: 0973
ECU: Transmission control unit
Status: Pending fault present during this driving cycle
OBDII: Shift solenoid (SS) A - circuit low
============2==============
P0976
Raw code: 0976
OBDII: Shift solenoid (SS) B - circuit low
============3==============
P0979
Raw code: 0979
OBDII: Shift solenoid (SS) C - circuit low
============4==============
P0982
Raw code: 0982
OBDII: Shift solenoid (SS) D - circuit low
============5==============
P0985
Raw code: 0985
OBDII: Shift solenoid (SS) E - circuit low
============6==============
P0962
Raw code: 0962
OBDII: Pressure control (PC) solenoid A - circuit low
============7==============
P2764
Raw code: 2764
OBDII: Torque converter clutch (TCC) pressure control solenoid - circuit low
============8==============
P0970
Raw code: 0970
OBDII: Pressure control (PC) solenoid C - circuit low
============9==============
P0966
Raw code: 0966
OBDII: Pressure control (PC) solenoid B - circuit low
============10==============
P0708
Raw code: 0708
OBDII: Transmission range (TR) sensor - high input
============11==============
P0712
Raw code: 0712
OBDII: Transmission fluid temperature (TFT) sensor - low input
============12==============
P0882
Raw code: 0882
OBDII: Transmission control module (TCM) - power input signal low
Alternator/Battery system. Seems like alternator is not charging your battery, or your battery isn't accepting the charge.
If it was fine before sitting, I would start with the battery connections. Also take the battery to Autozone (not sure where you are ) and have the battery tested. If it is good but low on power, have them charge it for you. When you put it back in the car be sure to check the cables and connectors and tighten them good. If the car runs, I would take it and have the alternator checked to ensure it is working.
