Unlock the DVR
Jon Jackson
Not sure if this will work for the Genny...anyone know?
Hyundai DM-R500
Open the disc tray
Press SETUP
Go to the bottom of the menu bar with the RIGHT key
Then go to the bottom of the menu with DOWN (entry should be named "Default")
Press 5
Select "Secret"
Press ENTER
The number that follows "Secret Code" is the RC
Select desired RC (0=codefree)
Press ENTER
Press SETUP again
Hyundai DVD-320A / DVD-360A / DVR-510C
Method 1:
Turn on the player (without a disc inserted)
Press 7, 7, 0
Method 2:
Press 7, 7, PLAY
Select region (0 = multi-region)
Press SETUP
Method 3:
Open the disc tray
Press 3, 8, 0, 0
Select RC (0=codefree)
Press SETUP
Close the disc tray
Hyundai DVR-510C / DVR-900A
Make sure no disc is in the player
Press 7, 7, 0
Hyundai HDP-380
Open the disc tray
Press SETUP
Press 9, 3, 0, 1, 0
Press STEP, SHUFFLE, NEXT
Hyundai HDP-550S
Press OPEN/CLOSE
Press STOP
Press 1, 9, 9, 9
Press ENTER
Select "All"
Press ENTER
Press PLAY
Hyundai HDV-2000 / HY-7900
Open the disc tray
Enter 2, 5, 8, X, (X = region code; 0 = multi-region)
Press ENTER and ignore the error message
Press PLAY
Hyundai HU-555
Open the disc tray
Enter 8, 9, 2, 6, X (X being the region code; 0 = multi-region)
Hyundai HU-2010
Open the disc tray
Press SETUP
Select "CUSTOM SETUP" (press RIGHT 3x)
Press 3, 3, 3, 3
Select the region (codefree = 0)
Press SETUP, exit menu
Hyundai HU-DIV3899
Open the disc tray
Press SETUP
Go to "Preferences Page" (don't enter it)
Press 1, 3, 7, 9
Enter the region you want (0 = multi-region)
Press ENTER
Power off
Hyundai HY-1020
Open the disc tray
Press VOLUME UP and ST-MO simultaneously
Press ST-MO
Select the region
Press ENTER
Press SETUP
Hyundai HY-3430
The disc tray has to be empty
Press SETUP
Press NEXT four times
Set "Vers" to "255" using the arrow keys
Press SETUP
Hyundai HY-DVD580
Open the disc tray
Enter 2405915
Press ENTER several times to set the region (9 = multi-region)
Close the disc tray
Hyundai DV-261, DV-3804B, DV-5-P 1211, DVR-530S, DVX-601P, DVX-701P, DVX-710SL, HE-DX230, HV-510, HY-01S4, HY-100A, HY-1015, HY-1910, HY-635PS, HY-9530, HY-DVD019
no known hacks
The primary benefit looks to be region free functionality for dvd playback.
Any way to have dvd or video file playback while driving?
believe you would have to disable the gps or the speedometer signal to the head unit. dvd is designed to cut out when car is moving
