Upgrading rear deck subwoofer on lexicon 17 speaker system for 2012 equus?
Brooklyn_Express
Equus (2011-2016)
Well im going all in...im removing 8 inch sub with a port to a box in the trunk to hold a 1000 watt 12inch...using module to change the digital signal to analog...adding amp and something to keep ohm level the same from input to keep radio thinking its still got stock sub...a remote bass knob to control amp from driver seat...
Anyone else try anything like this...or have upgraded their sub with alot better results? Would appreciate any feed back. Ty
OUsig
37
McKinney TX
I have not done anything yet, but I have the exact same audio system as you. I would suggest you remove the stock sub (like you said) then it depends on what type of bass you want. I think 1 sealed 12inch speaker with around 300-500 watts will be way more than enough. My previous vehicle (Acura TL) I had 2 12inch JL Audio subwoofers with 700 watts total and it sounded great! It would make my nose hairs tickle...sorry for the random mental picture! But seriously. You just need to remove the stock sub (or leave it in) and tap into the speaker wires going into it. Then simply run those to your amplifier if it has speaker level inputs, or if not then convert the speaker level to RCA. I would suggest getting an amp that has speaker level inputs.
And by the way, there is no need to try and design a port to shoot up through where the stock sub was. A sealed box (smaller and better sounding) with a good amount of power will be great
Good luck!
g_840154
Good luck!
Lexicon 17 speaker sound system is digital. You have to put a digital to analog converter to it unless your using a digital amp....then you got the ohm issue...this stock head unit will shut that xhanel down if it senses more ohms on sub channel...adding amp will do that by the way.
carguy75
738
Atlanta, Georgia
You may be able to remove the stock subwoofer and then tap into it's speaker leads so that the impedance(ohms) do not lower to prevent the stock amp from going into fail safe.
Brooklyn_Express
Equus (2011-2016)
Maybe...but i think amps add like 10 to 20 ohms on line.
carguy75
738
Atlanta, Georgia
Well, there is one way to find out. Break out the multi-meter and check the resistance of the factory amp leads connected to the aftermarket amp input without the subwoofer connected and with the subwoofer connected also.:)
slvslv
12
Kansas
Equus (2011-2016)
Did you or anyone else ever do this upgrade? Did it work ok? Please post your results and any pertinent information as there are several of us considering doing this as well. Thanks! See current thread on this subject:
2016 Equus Signature - Weak Bass?
Brooklyn_Express
Equus (2011-2016)
Yes mission was accomplished....i used a digital to analog converter from speaker wires that went to stock sub-to converter-to capacitors to drop ohm to stock factory speaker ohm pull- to analog 600i watt rms kicker amp to 1000 watt 8 inch jl audio 8 inch subs in bandpass box then redirected ports to one big port going straight up to open hole in deck. Battery is in back and put quick dissconnects on everything so when i take my Equus to service i pull out whole 50 pound box with amp and everything attached so my dealership dosent bust my chops.
slvslv
12
Kansas
Equus (2011-2016)
carguy75
738
Atlanta, Georgia
Not true. My stock digital amp for my 17 speaker system in my 2015 5.0 is still playing music thru my subwoofer channel I used to tap for a signal for my aftermarket amp. No fail safe is being triggered. I only use a analog line out converter and wire taps to tap the subwoofer channel and feed a clean signal to my stock amp. Nothing special needed. However, i do have a Genesis not Equus so there may be some differences. Yet, i believe both 17 speakers systems are nearly identical.
G-114692
Simple LOCs work perfect, I added 2 12 American Bass XRs and an Audiopipe 1500.. sounded magnificent!
brucehulkbanner
21
MD
same here. added two 12 inch Rockford Fosgate P2 with Rockford 1000 and it bangs. Trunk does a great job of containing base somewhat. Put foam under the rear license plate. sounds clean
