FOR SALE: Uyuni White Touch Up Paint (New) $20 +Shipping
skiingj
Roseville, CA
Genesis GV60
UYH Uyuni White Touch Up Paint Kit (New)
*Bought on Amazon. Decided I am not going to use, car is leased and there is some clear coat damage.
$20 +Shipping - Paid $36.53
About this item:
Compatible with Genesis models. Paint2Fix Touch Up Paint prevents rust and is easy to apply. You can't go wrong, just remove the touch-up paint with our patented Touch Up Paint Remover and try again.
Paint2Fix Touch Up Paint is a new product that allows you to easily repair small scratches and stone chips on your car. It has high quality pigments and a long lasting formula so you can get professional results.
Easy to Use. It comes with micro retouch brushes that let you apply the paint precisely. This makes it convenient for users of all levels.
Fast Drying. Paint2Fix touch-up paint dries quickly. This means you can use the vehicle again quickly after painting. Durability: The paint can handle UV rays and weather. It will last a long time and won't fade or crack.
Here's what's in the Paint2Fix touch-up paint kit: - Paint2Fix Touch Up Paint. - 60 ml of patented Touch Up Paint Remover - Five micro brushes. - Application gloves. - Special blue cloth and firm sponge to use with the Touch Up Paint Remover. - Detailed instructions
0.84 Fl Oz (25ml) of paint will repair 10 to 20 scratches and chips. 1.35 Fl Oz (40ml) of paint will repair 20 to 40 scratches and stone chips. 2.53 Fl Oz (75ml) of paint is best for many scratches and stone chips. (The exact number of scratches and stone chips that can be fixed depends on the size of the scratches and stone chips).
Dye Volume: The 0.84 Fl Oz (25ml) and 1.35 Fl Oz (40ml) dye volumes fit in 1 jar, so there is 1 jar of dye in the package. The 2.53 fl oz (75ml) dye volume fits in 2 jars, so there are 2 jars of dye in the package.
Color matching. Paint2Fix has an advanced color system that can perfectly match the original color of vehicles. These paints are prepared according to color codes, so you're sure to find the right color for every make and model.It's very important to buy touch-up paint according to the color code of your vehicle.Please make sure that the color code of your vehicle is UYH. You can find the color code on the vehicle's labels, usually on the driver's door sill.
*Not responsible for manufacture errors in description.
As long as it is still good paint, I will offer $25 shipped.
Sorry I missed this reply. What is your zipcode?
Sounds good. Does Paypal work? I can not send a DM to you. "You may not send a direct message to the following recipients: SoCalG90."
SOLD
