Vibrating
Lala827
My 2016 Genesis has started to vibrate when I brake. I need help because I’m afraid to go to a shop and they charge me for stuff that my car doesn’t need.
You probably have warped rotors or pad build up material on them creating a shutter affect when braking. I’d find a trusted brake shop to look at the issue for you. New pads and maybe a light rotor turn will usually fix the issue. Sometimes new rotors are not much more cost than just a turn job alone.
Thank you.
Exactly. Tends to be front brakes mostly. I had a neighbor that would do that with any car she drove for a few days due to her braking habits. Don't overheat the brakes. Warping can also happen if the lug nuts are not properly tightened when a wheel is put on.
Last time I had brakes done the local trusted shop was $100 less than the dealer.
Welcome. Moved to proper section.
Probably is rotors, but them good front rotors on the car are expensive. At least for the 5.0
Turning should be much cheaper if a viable path.
