STL_Genesis
- Dec 27, 2018
- Location
- Midwest - St. Louis
Recently, the voice command in the head unit does not seem to be functioning properly on my 2016 3.8 ultimate. I have an iPhone and the car connects via bluetooth just fine every time. I used to be able to press the button and "Please say a command" text with a beep would play. Now, the car does not offer a voice prompt. After I press the button, I can still speak and it recognizes the command and it does follow the instruction, but it is not working properly and for various reasons it is helpful for it to function properly so I know how to interact. Nav guidance works fine (voice guidance provide directions). I have looked at the different settings for voice command (the three levels of interaction), and change the setting to see it this made a difference. Nope. look all over in the voice settings, change the language, adjusted everything i could find and tested functionality. I have used the wired/USB connection. No luck. Looking around I can't seem to find an instance of this issue. Any thoughts on a fix outside of resetting the system (I would rather not)? Thanks!
