Voice Command Stop Navigation
tompass
SC
Worked at one time. Recently tried end route, stop navigation, stop route, cancel route and all it does is say route recalculating. Suggestions?
Computer glitch resolved at next startup!
Bus with passengers heads downhill when driver realizes he has no brakes. He is a professional driver with much experience and scapes off speed with gears and hand brake, rubbing the curb, and comes to a stop safely. He calls for reserve bus while all wait. Engineer passenger checks and says "I see the issue where the designer routed brake lines too close to engine heat source. I bet that is your issue. I could redesign this safely in my office." Mechanic onboard investigates and says " If I had my tools I could cut and crimp here and re-route line and we could be on our way." Computer specialist says "We should push it to the top of the hill and come down again to see if it fixes itself."
But that is really what worked. Appears to be same when experiencing no audio on radio.
