Washer fluid reservoir removal
igsrbest
How difficult is it, to remove the reservoir tank on a 2015 G80 sedan? It seems like it's tucked away quite well and hard to get to. The fluid is not spraying well out of the nozzles and I was hoping to clean out the tank and the inlet screen. I am not a mechanic nor do I play one on TV just saying. Thanks for any help on this project.
It's not too bad, I think. There is one bolt at the top holding the filler neck. Remove the front right inner wheel liner to get to the other two bolts that mount the reservoir.
Let us know of your progress - I have to do the same thing.... Mine leaks like a sieve on the ground when I try to use em. Think I have a hose problem though as the tank is holding fluid.
