What Da @$#!.........
MADDMOE
NY NY
.....So the last couple of days I started hearing this annoying noise coming from the rear passenger side wheel (like opening and closing an old iron board, very annoying sound)....I'm thinking is my shock bad, I did the complete R-Spec upgrade in 08/14..…....but after tearing the rear apart I found the issue .....the bushing/spacer attached to the knuckle has a rubber boot on each side with a silver ring that is supposed to secure the boot in place and you can see from the pic that it came off and dirt and grease and that NOISE was dealt with....I pumped grease all in and resealed the rubber boot with a wire that I twisted around the boot & twisted the ends til it tightened up better than that silver ring did....
.....ok so a few days later and the noise is creeping back , which leads me to ask does anyone know of the part # of the lower Bushing (black boots on both sides with silver ring) that's in the rear passenger knuckle (Hyundia part # 52720-3T000), the lower control arm rearward attaches to it........not looking to purchase the whole knuckle if I don't have to......thanks in advance
I found the part # 52720-3T000 but I just need the lower Bushing , that's something not listed .....I'm hoping I don't have to get the whole rear knuckle just because of that one bushings
How does that happen? These cars don't seem old enough for a separation like that IMO.
Well be that as it may.......it happened and the sound isn't as bad because I pumped in grease but if I don't find the correct bearing than Ill either clean it out again and this time pump it some silicone rubber or get a new rear knuckle (which may be what I'll wind up doing)
Nice(y)
