What did you do with your DH today?
ldp82
I think I might need better tires with a better grip now....oops! I said that? ;)
Let me know how you like the 4s. I will be needing to replace the Pilot super sports on my GT350 soon and was looking at the 4s. I just wish it came in a 305/35/19 as the 30's will lower the car ~.5" and I already scrape.
dareckibmw
Supporting Member
SUPPORTING MEMBER
2,072
322
83
Romeoville, IL
Genesis G80 Sport
carguy75
153
43
Atlanta, Georgia
Today I changed out both of my turn signal bulbs since the passenger side was burned out. I used some darker colored amber 2357 N/A bulbs as replacements. The old 2357 A bulbs were more of a light amber/yellow color.
The job was a bit more involved than a normal signal bulb change because I had to remove both of my air boxes to have proper access to the turn signal bulbs. Not especially hard, but a bit more time consuming than I am used to compared to other cars I changed turn signal bulbs on in the past.
However, I do like the look of the darker amber bulbs better than the light amber. The dark amber bulbs give my Genesis more of a European look when the DRL are on.
crizzlec
21
The pedals look great! How long did the swap take? I'm seeing the OEM brake and accelerator pedal set for $59.99 on Amazon. Trying to decide if I want to do that, the illuminated door sills, or the fog lights first.
I did pull the trigger on a new rear plate frame and a G80 badge.
dcrob95
7
I paid about $53 on eBay, OEM, shipped from Korea. They were delivered very quickly. As far as the install, it's super easy. The brake pedal just basically clips on after you remove the original rubber piece. The accelerator is just two 10mm bolts to remove then disconnect the connector, plug into the new pedal and put your two bolts back.
bigdaveinomaha
4
Replaced my trunk wing the other day. I screwed it up though. When I initially put on the wing it was very slightly off center to the right. I had to pry it back off and when I did I put a huge scratch in my trunk, one day after I bought it. I was so mad at myself! I bought a touch up pen and polished it. You can still see it up close, but if you didn't know it was there you wouldn't see it. My car also came without floor mats so I bought weather tech all seasons (I'm in the snow belt, Cleveland, so worth it). I also had the interior fully detailed as my car was a smokers car I think. Detail worked very well as there's zero remnants of a smoke odor. I'd love to do the fogs but I'm not technically inclined with wiring AT ALL so that may not happen.
Dream951
10
Wisconsin
Looks gorgeous. How did you make the eyebrows brighter? Also, do you use custom switch for DRL's or they are automatic?
Thanks!
I followed this thread to get the brighter eyebrows: (#easy) You want a LED DRL on your US Genesis? Read on.
And as for the the DRL’s and fogs, I have the fogs hard wired to the ignition and I use the DRL’s in manual mode by having the switch set to the parking light mode on the stalk to get the appearance I wanted.
dareckibmw
Supporting Member
SUPPORTING MEMBER
2,072
322
83
Romeoville, IL
Genesis G80 Sport
crizzlec
21
Those look great. I'm still trying decide between WeatherTechs and TuxMats.
