What is the widest tire for 18 x 7.5 standard rim?
Sure
I have an '09 4.6. I'd like to go wider on the tires, but keep the original 18" rims. (I think they're 18 x 7.5). Right now I have 235/50R18.
Any suggestions?
Thanks
QuantumRift
37
Central OH
I did this years ago for a Dodge Shadow I had...and the results were OK.
There a several sites that can show you how, or just call your nearest Discount Tire store...
http://www.yokohamatire.com/tires_101/customizing/aspect_ratio_calculator/
You have to be sure that the tires allow clearance when turning and going over bumps, etc (suspension travel), so you won't want to go to a "TALLER" tire. You want a somewhat wider tire while maintaining the same diameter (18" wheel and tire). You also want to keep the speedometer error to an absolute minimum.
http://www.csgnetwork.com/speedocalibcalc.html
If you wish to keep the stock rims, you will probably find that your choice in tire sizes is very limited. Ultimately I was able to fit wider tires on my Shadow's stock rims and liked the better feel, but the tires were pretty expensive as it was an odd size.
Any suggestions?
Thanks
jnc2000
Wider tire on that size rim would mean your sidewall could potentially have more flex / give. The extra 20mm in width would work (and I've seen it done) -- I'm just not personally a fan of it.
IMO get a wider rim if you want to go wider then OEM.
QuantumRift
37
Central OH
Yes, the consensus is go wider rim for best fitment...you may or may not notice a.5" difference in handling (1" overall for both sides). As for sidewall flex, I don't think that would be much of an issue with as low profile tires as they are...not much sidewall there to flex. When I put the wider tires on my Shadow (I used Cooper Cobras), I did run it a few times on the 'cone track' with the local racing club...end result is that I didn't notice a LOT of difference but what I did notice I liked. The stock rims and wider tires had more sidewall than the Genesis does, but the sidewall flex wasn't that noticeable on the course...
DavidHanLee
Just wanted to revive this thread and get some opinions from other owners as well. I need to purchase new tires and want something that is wider. Any reported sidewall flex from other members that went with a wider tire?
Pedal Commander
