Wheel options
Lonerider74
I have a 2020 3.3 AWD with Brembo with the 19 staggered setup. I have to go to aftermarket wheels, what are some options on wheels size? The tires only have 13k miles on them so no point throwing them away. I was looking at different options, so can I do a 19 x 8.5 on all four. Can I put that size on the front?
We don't yet have all the details for the GV70. Can't really answer that until we get all the wheel/offset specs. (You are talking about putting your wheels on the GV70, and not G70, right?)
loops, yeah wrong forums. im talking about the G70.
  • Like
Reactions: Imp
I haven't been able to find info about the wheel / tire set up, specifically, does anyone know if all four wheels are the same size, especially on the Sport models? Typically on the competitors high performance models (such as the GLC AMG 43) the rear wheels are larger, well, wider than the front.
I've been following the car for quite a long time and I haven't seen any evidence to suggest that all four tires are not exactly the same.
The wheels and tires are the same size all around. Please see the below.Genesis GV70 Wheels and Tire Specifications.jpg
The wheels and tires are the same size all around. Please see the below.View attachment 36558
Excellent! That means they can be rotated (I would assume?).
One of the things that scared me off of the German makes was the different tire / wheel sizes.
Thanks for the information! GV70 looking better all the time!
Glad I saw this
Can you please tell me where you found this chart? I looked all day and couldn't find any wheel specs for my new GV70 Advanced. My dealer couldn't either. Shocked me.
Thanks
Difference in wheel or tire size front to back is one factor in rotation. The other if the tires are directional...which means they are supposed to spin in one direction only for main forward travel due to the tread pattern being designed to direct water from under the tire out to the sides. Directional tires limit rotating from one side of the vehicle to the other. I don't know what tires you're equipped with, but often there will be some form of arrow on the sidewall identifying spin direction if it is directional. You can also sometimes tell by looking at the tread pattern where the tread seems to have channels that angle away from the centre.
