Wheel question
Cannon
Genesis GV70
May be a stupid question, but will any other wheels from Genesis models like G or GV80 or G70 fit the GV70?
You'd want to check with the dealer parts dept on the wheels your considering to see if the bolt pattern and wheel offset is the same as your stock wheels.
Bolt pattern should match...all Hyundai Group, as far as I know, are 5 x 114.3 bolt pattern. What you have to be aware of is the diameter as you want to ensure you clear the brakes, offset for the same reason. I think the Select has an 18" wheel but personally, would not go lower than 19" to be safe. Offset of the 21" (9" wide) GV70 wheel is +43. Anything higher, which may be possible with other Hyundai or Genesis wheels, again, may result in contact with your brakes. Most tire shops will recommend dry fitting the wheels before committing. If I had to guess though, I suspect most if not all Genesis wheels of at least 19" diameter will fit.
One thing you do need to check, however, is whether all Genesis vehicles have lug bolts (as does the GV70) instead of the more common lug nuts. It just could mean that you would need to find new lug bolts to fit other wheels, presuming the seat of the lug is different (ie. not conical) or you need longer or shorter bolts.
