Wheel spacers
JKTurbo
Can you add wheel spacers to the stock rims on the 2023 3.3 sport prestige model.
I had the wrong platform.
I have 30mm on the rear of my 2022 3.5 SP. You need different bolts and nuts as well.
30mm is very long. (More than one inch for those who don’t know metric). Those wheels must look strange. Over two inch wider rear track.
If you did this on the front, it would upset the steering geometry.
Even 15mm would change your scrub radius significantly. I don't want my front scrub radius off by more than 4-5mm, preferably less than 3mm.
The only reason to do this is for looks, so if that's what you're after, there are plenty of folks who have done similar and are apparently happy with the results.
