Wheels
Tom328
Has anyone use wheel adapters ? I have a set of rims that was on my Jag an I would like to put on my Sedan . I know the offset is different. The rims I want to put on are 18 x8 an genesis has 17x8.
Also, there is some wiggle room in that offset. It does not need to be exactly 38mm. The problem you will run into is that Jag never used a 5X114.5 bolt pattern, and who knows if the center bore will work. Next issue is that I highly doubt Jag, being rear wheel drive vehicles, have a really high offset, so by the time you get proper bolt on spacer/adapters, you're pushed way too far out.
