When i turn AC on the driver side blows hot air while passenger only cools
pulsar
175
104
43
DFW
No Genesis Yet!
Your air mixture damper is not working correctly. Should be a small servo motor under the dash along the air ducting that moves the damper from hot air to cold air. This is probably stuck in the hot mode. If you can find the right servo you can usually remove the servo and move the damper manually. You may have to rig something so it stays in that position. Other cars have the same issues. GM cars after 4 or 5 years are famous for these isssues.
Mickeymiguel13
It does the opposite
I put heat it blows cold
I put Ac it blows hot...i dont think the fan stuck on hot
[But when i turn heat on it blows cold sir
EdP
Supporting Member
SUPPORTING MEMBER
5,681
2,339
Parrish, FL
Mickeymiguel13
Read what you originally wrote. Driver side hot, passenger side cool. It is not the fan stuck on hot it is the damper in the ducts directing air that is stuck. The fan is just a fan, the dampers determine if hot or cold goes to the right spot.
As pulsar pointed out, it is common on GM cars. Had the same problem.
Ok thanks i appreciate it ...ill go under dash and check
Pedal Commander
